-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   Leverage HELP.... (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/226241-leverage-help.html)
86BAJA 03-12-2010 10:04 PM
Leverage HELP....
Ok So I ordered The Leverage product line. I got the Hull Cleaner, OR, And Polish. Tomm Morning I'm Getting up early and starting my detailing project and dont have a clue where to start. Was Wondering if someone could help with the order in which i should use the products and how they should be applied. I know there a million threads on here but i need it broke down to the most basic level due to this being my first boat and my first detail. Thanks For The Help.
Griff 03-13-2010 01:04 AM
The hull cleaner is pretty much for stains on the bottom or at the water line. Here is the way I would do it.
Use the hull cleaner to remove any stains, then dry the sides and deck. Next start on the deck with the OR and then do the sides with the OR. When you are and satisfied with the results of the OR, then wash the entire boat some Dawn dish soap. It will remove any old wax and dirt still left and the OR residue/dust. Dry the boat completely and go have a few beers, cause your arms are going to be tired. Then apply the Leverage Polish.
86BAJA 03-13-2010 12:26 PM
Thanks Griff, Off to start the project! I'm taking some before and after pics i'll post later tonight.
johnny b good 03-13-2010 02:22 PM
I found after I used the O.R. with wool pads I had swirl marks, so then I used 3m's Finesse it swirl glaze and then I went to the Leverage Polish with awesome results. I am by no means an expert at detailing and it sounds like a lot of people can go from the O.R. to the polish but I had swirl marks that had to be removed first.
86BAJA 03-13-2010 06:42 PM
Done for the night and not even close to getting done what i had hoped. Now i know why everybody complains about detailing there boat. got the front deck done.....yep thats it just the front deck...pics to follow...diggin the leverage products huge difference.
RT930turbo 03-16-2010 10:17 AM
it's a time consuming process to do it right. My boat was painted with IMRON, and needed wet sanded first. 800, then 1200, then compound, polish, etc. you get the idea. It has taken WAY longer than I expected. Good luck, the results will be worth it!
86BAJA 03-16-2010 01:15 PM
3 Attachment(s)
Still workin on getting more color and just got the windscreen taken off to replace glass and re-paint frame. now if i could get my motors going i might be happy...:lolhit:
marineclean 03-19-2010 12:22 PM
Looking good Baja! Hard work, but well worth the results! I'm only on OSO about once per week right now, so if you need anything please post up and I'm sure one of us will chime in.
twanger 03-19-2010 01:16 PM
I removed some stickers last year on the sides and under the stickers is bright white and where the stickers werent covering is yellowed. I did some wet sanding this last week with 1000 and I still cannot get the yellow completely gone. I am going to use the OR next trip to polish it out and see if that helps the yellowing. It was alot of work and I am still sore.
Anyone have any ideas? About the yellowing not that I am out of shape.
Griff 03-19-2010 05:12 PM
That is the issue with removing vinyl or painted graphics whether it be from a painted or gel hull. The longer the graphics were on, the less likely you will be able to blend out the spot from where the were removed.
low_psi 03-19-2010 07:15 PM
86BAJA,
Are you putting the teak boards back on the bow or are they painted? My 84 Force 250 had the Teak boards, I sanded them smooth and finished with Sikens and they look awesome. I love the lines and use of teak on the older boats.
86BAJA 03-19-2010 10:54 PM
PSI, Ya I actually just got the teak done and when I finish the windscreen i am going to put it all back on. I got all black plexiglass non-see through ordered and re-doing the frame myself actually started the sanding tonight (not fun). If you have some pics send em i always get ideas looking at other boats...Question?...What is sikens? is it just a version of teak oil or is a gloss finish on the teak? First boat so still learning a lot.:drink:
low_psi 03-21-2010 12:16 PM
Sikens is a stain made for teak. I love the look of natural teak w/oil but it is WAY too much maintenance. Below are a few pics of my teak with a couple coats of Sikens.
http://site.activesportsunglasses.co...91018-1218.jpg
http://site.activesportsunglasses.co...91017-1449.jpg
http://site.activesportsunglasses.co...91018-1221.jpg
Also you might want to consider removing the railings. I took mine off and just filled the holes with a stainless bolt and some silicone. It will give the boat a much sleaker look.
http://site.activesportsunglasses.co...91018-1222.jpg
