Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
gel coat worn thru on bottom >
Old 04-26-2010 | 09:42 AM
Shore Thing's Avatar
Default gel coat worn thru on bottom
So i spent the last 2 weeks sanding through 20 years worth of bottom paint on my center console (my wife has been calling me smurf). In some places i went too a little too far and sanded all the way through the gelcoat. I just put in a lift on my pier for the boat, so it will never sit in the water for more than one day. My question is this....
I plan to paint the entire boat next spring. Do i need to re-gel the areas that i sanded thru for this summer? If it's necessary, i'll certainly do it. But the spots are below the waterline and not visible, so if it isn't necessary i just assume leave it as is and not do the extra work until painting next year.
Thanks!
Shore Thing is offline
Old 04-26-2010 | 10:53 AM
rchevelle71's Avatar
Yes,
even though Gel is not completely waterproof either, I would gel it to keep it from seeping into the rest of the bottom, also, there is some serious water pressure when running, without the smooth gel surface, it can get between the glass layers, and start to delaminate.
rchevelle71 is offline
Old 04-26-2010 | 12:01 PM
Thanks! that's the validation i was looking for.
Old 04-27-2010 | 08:01 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
I also would advise fixing the sand thrus... Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
