-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   removing graphics ??????? (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/248215-removing-graphics.html)
sdodson1 03-01-2011 02:47 PM
+1 on the Rapid remover, just go to a local sign shop and buy a gallon. It won't hurt the paint or gel. I have been using it for years. Too late for the wheel if you already have the vinyl off. It's also very easy to burn gel and paint with one.
Wildman_grafix 03-01-2011 09:34 PM
I'll have to try it, I have used rapid tack for putting vinyl on.
sdodson1 03-02-2011 08:30 PM
I own a sign co and if anyone needs some Rapid Remover PM me and I will ship it to you at my cost shipping. My way of sayin thanks for all the great info I soak up here!
Sean
bert4332 03-02-2011 10:43 PM
How well did the Rapid Tack work after it was in the water for a few times?
Philm 03-03-2011 03:29 AM
I dont know what it would do to a boats gel, but by far the best adhesive remover I have ever tried, without a doubt, was 3m electrical contact cleaner. It was pretty amazing how well it worked. I didnt even spray it directly on the surface, I sprayed it on a rag and then wiped, one swipe took all the residue off.
I used it to remove the adhesive residue left over from the stupid ass operating system stickers on my Laptop (tough stuff), so I know it wont harm plastic.
ThisIsLivin 03-03-2011 12:34 PM
I use lighter fluid, the Napthalin cuts the adhesive but isn't hot enough to hurt the gel coat. I've seen Acetone and Goo Gone cause plastics to yellow over time. most of the adhesive removal products have Xylol and Tolulene in them which will hurt paint, plastic or fiberglass.
bert4332 03-03-2011 07:56 PM
I'm kinda baffled by information about Acetone hurting gel. I've watched several videos and read a few books all say clean with acetone prior fixing, spraying, ect... Now acids I've read not to use, such as toilet bowl cleaner ect... But acetone is a ketone, not an acid, if someone could please direct me to a link with negative information on gel coat.
thanx
Wildman_grafix 03-03-2011 09:44 PM
It's only used when putting vinyl on to give you time to work out bubbles or move the graphic slightly.
Works great, once it is dry the vinyl sticks as good as if you didn't use anything.
ezstriper 03-04-2011 06:02 AM
acetone won't hurt the gel..but I would worry about the paint !!! been using the rapid remover for years...works the best and is water clean up after..have a hose ready to clean up after..Rob
sdodson1 03-04-2011 08:16 AM
Yes 2 different fluids from the same company, as Wildman said.
Rapid Tac is an application fluid that aggravates the adhesive and actually improves adhesion while allowing you to move the graphic before squeegeeing to expel the fluid and "set" the graphic.
The remover is an orange oil based product that breaks down adhesive and gel's it. We usually spray it on then wait a few and scrape the majority off with a plastic edge then spray it and wipe clean.
