Delamination
Subscribe
05-06-2011 | 09:59 PM
So I had an area where I had some delamination from hull. I ground it out. What would be the next step? I was just going to get some glass and resin and glass it back to the hull. Opinions?
Reply 0
05-07-2011 | 06:52 AM
Grind out the area with a ruff grinder no paint under the glassed area you are doing then clean it with asetone then start your glassing
Reply 0
05-07-2011 | 11:33 AM
Personally I would take out that motor mount so that you have more room. I would grind back a bit farther. I am sure Glassdave can answer your questions about what glass and resins are best.
Reply 0
05-08-2011 | 12:38 PM
Quote: Personally I would take out that motor mount so that you have more room. I would grind back a bit farther. I am sure Glassdave can answer your questions about what glass and resins are best.
After Bitc#ing and trying to grind around the motor mount I never once thought about just simply unbolting it. LMAO
Reply 0
