twin to single conversion on a CAT
hi! i found a good deal on a 27 eliminator (hull only)but it has twins. i want a boat with a single.
(i know i know every body seems to like twins but i dont really want two engines sepecially in a 27 foot boat. ) my question: can this boat be converted to single engine? and if so wht would need to be done? i am a mechanic and do all of my own work so the labor cost is not an issue. thanks to all for the help in advance! |
Did the factory ever offer that hull as a single? i know they do now but not sure what kind of weight difference there is. As long as it has a pod i dont see why it wouldnt work but you may be in uncharted territory. You would need to put a transom in it to start
(Post 3450582)
thats weak. |
| All times are GMT -5. The time now is 02:42 PM. |
