best oxidation compound?
Old 07-19-2012 | 01:13 PM
I did my '82 Nordic with 3m products from amazon.com
rubbing compound/heavy duty
bounce is offline
Old 07-20-2012 | 02:31 PM
It depends on your experience buffing stuff. If you don't know what you are doing with a heavy cut its easy to burn through. Go with a finer compound or something like Buff Magic that changes as you use it.
inthetundra is offline
Old 07-21-2012 | 07:19 PM
If your boat is heavily oxidized, nothing beats Aqua Buff 1000 and a twisted wool pad. It will require some finishing work but it cuts through oxidation like nothing I've ever seen. It blows 3M Super Duty out of the water.
VCMike is offline
Old 08-01-2012 | 09:30 AM
Here are some before/after pics of a yellow boat one of our detailer customers sent us out of Maryland. The products used were Crystal Cut Compound, Crystal Cut Polish, and Crystal Gloss Wax. I believe he also used a DA polisher with foam pads.
Attached Thumbnails best oxidation compound?-yellow_1.jpg   best oxidation compound?-yellow_2.jpg
PBC 1 is offline
Old 08-04-2012 | 09:23 AM
I used a 3m wool pad with there heavy duty compound since it was local and fast for me to get. what a difference it did a great job.
zeke is offline
Old 08-08-2012 | 01:08 PM
I have a Red and Black IMP that had heavy oxidation on the sides (black was almost a light grey). I have had it for 6 seasons. The first season i wet sanded it below the rub rail, went over it with 3M compound (cotton pad), and buffed it with ??? (can't remeber) - But, it held up pretty good till this season. Not sure if i did it right but it worked well. The boat is stored outside about 50% of the summer...
Scotty81 is offline
Old 08-08-2012 | 02:42 PM
The worse the oxidation, the more frequently it needs to be polished to retain the shine. If it has been wetsanded, that frequency also increases.
VCMike is offline
Old 08-10-2012 | 02:46 AM
Default Harmful
Originally Posted by mrfixxall
cmit kitchen clensor...yes it works,,just add water and sprinkle and go to town..another good onr is aqua buff..look on ebay.
Cmit kitchen clensor is a good option but is a bit harmful for the surface.
RTA Cabinets
tenosanremp is offline
Old 08-10-2012 | 09:12 AM
the 3m Stuff worked pretty good. If you dont have a buffer dont even try it without one.
soldier4402 is offline
