Vinyl paint
Old 02-02-2015 | 01:06 PM
Default Vinyl paint
https://www.amazon.com/dp/B003QLH0NA..._ay8Zub1TVWY1M
Does these stuff work ?
riverboater is offline
Old 02-02-2015 | 02:52 PM
The only problem I found is that some sun block lotions could melt it and ruin clothes.
Cajun 2 Stepp is offline
Old 02-02-2015 | 04:18 PM
Is there any type of clear to go over top
Old 02-03-2015 | 08:22 AM
I've used for side bolster pieces on my previous boat (91 Pachanga). had the boat for 5 years and never had an issue. Never had to use it for seating surfaces though. at $15 can why not try...still a fraction of the cost of replacing the vinyl.
blckkat is offline
Old 02-03-2015 | 06:33 PM
Rookie's Avatar
There are a few threads on here about vinyl paint. I've personally have had great results using it. In sun and any sun tan lotion.
https://www.duplicolor.com/products/vinylFabricCoating/
Rookie is offline
Old 02-03-2015 | 07:36 PM
BUP
^^^^ what above said as the Duplicolor product is better. If I remember correctly, it is a cleaner / prep spray 1st and possible adhesion application 2nd then the Vinyl color paint lastly. It is a 2 part or 3 part application for the best results. Its like anything to do with painting - the finish product and longevity of it is all determined upon your prep work first.
BUP is offline
Old 03-01-2015 | 07:55 AM
I have been very impressed with the Duplicolor product!
RENCRN8 is offline
Old 03-01-2015 | 08:12 AM
I've used both SEM and Duplicolor on car applications. I've found that the Duplicolor has a tendency fo "fill" the grain on vinyl if laid on too heavy. The SEM actually soaks into the vinyl and doesn't scratch as easily. Just my experience.
Jonesyfxr is offline
