Rotten bulkhead HELP!
Old 04-08-2015 | 08:32 PM
  #111
Thanks phragle , always good to know!
buck35 is offline
Old 04-16-2015 | 09:54 AM
  #112
Originally Posted by phragle
Thats Whoya..he is a member here... Good guy to deal with.
Just wanted to give a shout out to Whoya, got the tools yesterday. Thanks again.
Dd thanks for pointing that out.
buck35 is offline
Old 04-17-2015 | 11:11 AM
  #113
http://www.jamestowndistributors.com...ilicone+Rubber
Marine store employee said this would work on my exhaust tails to seal them at the transom. The old stuff was black and pliable and the tails have some "give" when mounted. This looks to be the same. Is this a good idea or should I be using something else?
Also worth noting the tails are very close to the waterline on 32 Fevers...
Diamond Dave is offline
Old 04-17-2015 | 01:49 PM
  #114
You might want to use 4200,,good stuff
boatnt is offline
Old 04-17-2015 | 06:00 PM
  #115
Both 4200 and the silicone will work. Just that the 4200 will be a Bich to remove if you have to.
dunnitagain is offline
Old 04-17-2015 | 07:32 PM
  #116
^^^^^^ Like in the fall when you start the work.
Wildman_grafix is offline
Old 04-17-2015 | 07:34 PM
  #117
Well......? Lol
Old 04-22-2015 | 02:47 PM
  #118
Well after much debate and advice from everyone here we have officially decided to just run it this season and make the repairs in the winter. I know this project has the ability to steamroll into a much larger one very easily and we would miss out on summer if so.
I want to thank everyone for their comments and support to this point you all have been an incredible help as always and it is VERY MUCH appreciated!
That being said, since I have a heel size hole in my bulkhead what should I cover it with temporarily?
Before I ask this next question I want to preface it by saying that the center stringer and bulkhead will be repaired the correct way next season...but you had to see this coming lol... Is there something I can drill into the stringer and "fill" some sections of it with easily and temporarily to provide it some degree of additional support while running the boat this year? Just some extra security is my only idea here and maybe it's not needed who knows?
Old 12-08-2015 | 07:13 PM
  #119
I took this picture when I had the drain plug out to check for rot and I noticed the small hole drilled in the center stringer. I didn't think much of it at the time since I poked at it and it seemed solid. Now that the boat has been sitting there has been a blackish brown liquid oozing out of it... this may be one (?) of the culprits for my stringer and bulkhead being rotten. I also have a rotten smaller stringer on the starboard next to the main stringer I found out. I don't know how it could spread that far forward and also to the smaller stringer from this location alone but I guess anything is possible when talking about water and wood. Nice to have that hole that was drilled there... I am assuming from a pilot hole for the drain plug.
Old 01-30-2016 | 08:56 AM
  #120
Dave, how's it going over there? Going to be ready for the summer?
89Mach1 is offline
