Rotten bulkhead HELP!
#81
I dont know WM, I'd put the drains back in but just put some rubber plugs in them. Easier to pull plugs to drain water out in case the OP likes to hose out his cockpit, gets caught in a down pour, or boat gets left out with no cover.......than to figure out how to get all the trapped water out now with no drains. My vote is retain them but make sure they are sealed
I've used 4200, 5200, Life Seal or Life Chaulk. Depends on what's available at the time and the application.
#82
the wood i meant was where the exhausts and drain plug etc were removed. paint with polyester resin and let it harden to seal the wood itself up before reinstalling the parts. and 5200 is for a fitting you never plan on removing again. thru hull depth finders or water inlets below the waterline for generators and such. you need to be able to remove it? ever? not 5200...
#83
If I was you when you replace the bulkhead I would get rid of the drain. Plug it at the other end.
Did it cause the rot,,,,,,, hard to say. You know at this point the big thing is if you are going to fix it before the season or after. If you are going to do it now you have to get the motors out and at that point you will really be able figure things out.
For screws and such I have been using life seal. I think Brian41 sugested it on here. Issue with 5200 you will not be able to get it apart again.
#86
That is true but later ones don't have it. They do have a small pump under the cabin step. I would be a little concerned if water goes in and gets trapped around the fuel tank.
Seems there is good reason for both ways, might try one of the flip style drain plugs. My old hydrostream used one rather then a screw in, push it in and flip it up to expand the rubber.
#87
I had a pop up nav light in the bow that leaked and ultimately drained it the area under the v berth. I cut access panels out primarily to dry the compartments. When dry, I sealed them with resin and corrected the drain for the nav light. Never any water in that area again. In the entrance of the cabin of my 10 meter, the step was rotten from sitting water when in storage from prior owner. All of these older boats are suceptable to rot unless owners are meticulous.
Encapsulated in glass is not a guarantee either. In a boat whose cover leaked during the boating season, water pooled in the corner of the glassed floor. Enough leached through and rotted the deck. Found it when the owner stepped in that area, flexed the glassed and cracked. One square foot repair area. Rest of floor was solid.
Going to take some digging on your part. Remember, they all have secrets.
Good luck
#88
Just catching up on this thread . . . bummer.
I had similar issues on my 2 Formula's . . . fixed them both myself. In general these high-end boats are a lot more vulnerable to rot than one might think.
As far as getting the back-end fixed, plan on the actual area of problem and repair being 2X or 3X what you see at the outset. Having moisture & rot in the main bulkhead is a real problem as it easily spreads to the engine room stringers and the main stringers along the fuel tank.
Also the water that you found in the forward area is concerning as it could indicate water retention all along the keel. So, that would warrant a look at the forward bulkhead and even the foam in the fuel tank bay and possibly the fuel tank itself.
Not a good situation, but it probably needs to get fixed either to keep or to sell. Just plan on the actual damage and repair being larger than you expect.
#89
I think thats where the difference may lie between his and our boats. His being a '95 has drains thru the bottom of the boat, past/under the tank from the cabin to the bilge. Ours being newer, the tank compartment has no point of entry at either the front or rear, just the drains on the outside side of side stringers in front of the batteries for the cockpit drains. Don't know if his has this??? Since there is no way for cabin water to drain out of our boats, they put the small pump inside the step, thus why we have no finished bottom in the step compartment and he does as he has no forward pump. I just used a rubber tapered plug on my '94, A slight twist when pushed in, it was good to go and never an issue of coming loose.
Figure out where/why you are getting water in there in the 1st place and address that. You should be able to have it 100% dry.
#90
Scupper valve and wrong area for one. Should not any volume of water in those areas to begin with to need to "Pass through"
Good luck
Good luck
My bow light and the cleat are accessible from behind the mirror in the very front of the cuddy. I took it off to see if there was any drains that went into the "compartments" under the bed. There are no drains that go to the rear of the boat from that area. However iit has a little drain hole that goes to the outside of the boat...always wondered what that was for...
The weird thing is that in the compartments under the bed the drains have tubes that go to the rear as well as to the front. Where the front ones go I have no idea since there is no more places to access! ??
I'm starting to think that this boat was stored with the nose down and water collected in the forward compartments (as evident by the stains in the forward compartments under the bed) and under the cabin or whatever hot mess is under there then rotted out my bulkhead and stringer. This is my current "theory". And yes, I am in denial about my transom lol!
I don't think I will have any issues with water being anywhere except in the very back of the bilge storing it like this. The driveway is slightly sloped but it's for sure nose high and should drain everything in there. I reconfigured the blocks this weekend for a few more inches of lift on the jack. Theoretically I think on the trailer, on a level surface, this boat would be sitting nose down thus allowing bilge water to run forward and collect under the cabin or what ever is underneath there.
LOVE the comment "they all have secrets" LMAO!
