Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Recommended compound product >
Old 08-19-2015 | 05:10 PM
Default Recommended compound product
ok, got my first polisher (Shurhold, multi point spin) and liking the results I am seeing on my black hull (sides, lower half is white), it came with some Pro Polish that works real well on my like new gelcoat. Not faded, oxidized, etc. Garage kept. I have some bunk rash I want to remove from the keel. I am no expert on using this polisher, but think with the right compound, I could get this bunk rash out. Not thinking too aggressive, but enough to cut some. I can feel the rash with my finger nails. Thoughts? Thanks, in advance.
imartin is offline
Old 08-19-2015 | 09:08 PM
glassdave's Avatar
Neno the mind boggler
Fountain of Youth - Tottaly Buff
it cuts pretty well for a finer polish but what I like is its diminishing properties, breaks down as you work it and clears out of the pad (wool) well. Easy clean up to.
08 OPA High Points Champion
glassdave is offline
Old 08-19-2015 | 09:32 PM
Thank you sir, many speak highly of that product line....
imartin is offline
Old 08-27-2015 | 07:33 AM
3M rubbing compound works great
The Polyflaker is offline
Old 08-29-2015 | 09:18 AM
Many good products out there. Technique is key. Have had great results with 3M, Wizzards, Presta and Performance Boat Candy. Really like the Performance Boat Candy, as it creates less dust and requires less pad spurring. I also have a friend who is a dealer, so cost is right!
Cory H is offline
