epoxy hull?
yes, see my above edit . . . an it was a Fountain. Actually mid 90's to early 2000's there were a few builders trying to make it work.
08 OPA High Points Champion
When I was up in the Outerbanks in 94 building the big wood epoxy Sportfishermans ,I bought a 16 foot Carolina skiff that had split the outside skin down the middle about 7 feet.
being I had easy access to epoxy I repaired it with that and a week later gelcoated it.
That did not go well .The gel didn;t seem to ever cure properly where it met the epoxy.
Ended up grinding the mess off and painting it.
theres really not a whole lot in terms of use that would differ from a poly boat. its just when you need to repair it that it needs to be addressed.
Fill us in Oh Wise One.
Please
Ill try posting a pic again although ive had no success for quite a while. [ATTACH=CONFIG]546434[/ATTACH][ATTACH=CONFIG]546434[/ATTyACH]
edit he did say you got a good one , maybe some not so much.
