Coring replacement
Old 12-03-2015 | 08:53 PM
Default Coring replacement
Repairing a 17' bass boat, the hull was completely compromised and had to remove floor, stringers, and bottom coring. When I replaced the bottom coring I used 3/8 thick balsa core that was cut in one inch squares and held together with scrim. I used 1.5 mat wetted out slow cure mix and layed the coring on, then used packs of roofing shingles to hold down until resin cured. I seem to have a good bond to the hull with the coring. My question is should the coring be sealed up before I laminate over the new coring. I did a small section in the front and it seemed to take excessive resin to fill up all the voids in the coring squares and the coring itself. Did I use the wrong coring material with the squares? I was thinking of using a cabosil mix peanut butter consistency to seal the coring before lamination, or is it normal to fill all the voids with resin. Using resin seems heavy and weak to me.
No Coast is offline
Old 12-03-2015 | 09:59 PM
c_deezy's Avatar
I would do a hot coat of resin over the core to seal it up, then do your finish laminate.
c_deezy is offline
Old 12-07-2015 | 11:53 AM
Would a hot resin mix applied with a roller work? That should provide enough to seal but not fill up the voids. Then start laminate next day.
No Coast is offline
Old 12-12-2015 | 08:02 AM
I Would fill the voids with resin. Otherwise your voids between balsa will be like a void in the laminate. Every balsa core Ive ever ground was filled with resin. You could have used Coosa for your core.
That's some gooood S--t!
dunnitagain is offline
Old 12-13-2015 | 08:39 PM
I think using the flex style balsa cut into squares was my mistake. Regular coring would not have needed so much resin. Next time I'll know.
No Coast is offline
