Fiberglass windscreen
Old 06-23-2016 | 12:00 PM
Default Fiberglass windscreen
I have a 88 baja 240 sport and was looking at getting rid of the old glass, aluminum framed windshield and was looking at doing some sort of fiberglass windscreen. Like on the outlaws. Has anyone done this or have any suggestions on how to do it
cjw9255 is offline
Old 06-24-2016 | 12:50 AM
scippy's Avatar
[ATTACH=CONFIG]556730[/ATTACH]
I built one for my 27' Magnum.................You can use the aluminum frame as a template. I was not that fortunate since my boat had no windshield. I just mocked up a cardboard template and transfer it to 1/4" luan (plywood)
There's a lot that goes into it, I won't say it's easy if you have no experience with laying up fiberglass, but neither did I............materials Vinylester resin, 1.5 oz. mat, 1708 glass & 1/2" balsa coring.
scippy is offline
Old 06-24-2016 | 10:03 AM
Thank you this helps a lot! Another question did you do yours as a one peice?
cjw9255 is offline
Old 06-24-2016 | 12:41 PM
scippy's Avatar
yes One piece...........once you get the right form and angles in cardboard then transpose that to the base materials (I used 1/4" luan (plywood) you can rough tack it in the corners) to hold it's form before you get the first layer glass on.
scippy is offline
Old 06-24-2016 | 08:11 PM
I've always wanted to do one on this old corsa hull, but more rounded.
hoodoo is offline
Old 06-24-2016 | 08:23 PM
I don't know if a previous owner or wellcraft did my old scarab 400 but it is absolutely seamless
And I have never seen another 40 like it.
Phantom boats here in sarasota has a nice one on their open cockpit 30's and could probably pop one out of the mold to fit.
hoodoo is offline
Old 06-28-2016 | 04:39 AM
Default Dave xt innovations
Call dave at xt innovations, he worked at baja and can tell you more about your boat off the to
Of his head, nice guy, he would be able to help,you out
Www.xt-innovations.com
Give him a shout
Jj
conneroutlaw is offline
