transom ?
Old 01-22-2018 | 09:01 PM
Default transom ?
Replacing transom on my Pantera. I have plenty of glass experience and do everything old school still. Was planning on a good marine ply and ve resin. Buddy of mine trying to talk me into using epoxy and coosa board. My question is, is coosa worth the extra coin?
Duck Diggler is offline
Old 01-22-2018 | 09:32 PM
No, not for the transom.
phragle is offline
Old 01-22-2018 | 09:42 PM
Go old school
class6 is offline
Old 01-22-2018 | 09:44 PM
Are you going to a bravo drive ?
class6 is offline
Old 01-22-2018 | 09:55 PM
Yes, Thats the plan. Also, gonna raise the x while Im at it.
Old 01-23-2018 | 06:18 AM
Not an expert but for what it is worth, Velocity used coosa board in the transom on the VR-1 and other models.
Padraig
Padraig is offline
Old 01-23-2018 | 06:46 AM
Is your transom 2.75" thick?
class6 is offline
Old 01-23-2018 | 07:11 AM
What I was told, is that if you're going to run modest to big power you have to use plywood for the transom and engine stringers. Anywhere else you can use Coosa. I'm about to glass in my new transom, and I'm using 3 layers of 1/2 marine ply, with a layer of 24 oz woven roving in sandwiched between. Then to actually bond it to the boat, Core Bond B70 and 1708 glass.
endeavour32 is offline
Old 01-23-2018 | 07:25 AM
If you asking about the VR - 1 I don't know what the thickness is. I can't measure as she is in hibernation.
Padraig
Padraig is offline
Old 01-23-2018 | 02:06 PM
sounds like a glass dave transom recipe, and the best way to go !
have an x dimension all picked out yet ?
trs boat bravo conversion ?
how long is the engine room from transom to bulkhead or seat back ?
outonsafari is offline
