Gray color match Baja swim platform
Hi. 2007 Baja Outlaw with metal swim platform. Light gray, anyone know a supplier that might have the oem paint codes or info on the gray color for touch ups?
Most automotive paint suppliers will have a paint camera program which will give you close match or the exact color code. You will need to have the swim platform available for them to take the photo. I believe one of the systems is called Profit.
Aluminum swim platform pics and photos. Aluminum swim platforms designed for your boat. Perfect for your baja, baja outlaw, active thunder, advantage, american offshore, apache, awesome, baja, black thunder, checkmate, cigarette, donzi, eliminator, f
This is who you need to contact since they built and powder coated your platform when it was new.
If you have a local powdercoat shop nearby, they should have the color swatches you can use to match up the powder. I have some here, but I'm just a bit away from you.
Ugh! Strike one on the match. No go. Hope I didn't open a can of worms....says he can match on 2nd attempt. And we all just thought there were only 50 shades of gray! Lol...
Honestly I believe you would be better off removing it and having it powder coated like it was done originally. Way more durable and all surfaces will match. Only a 15 minute job to remove it as well.
