Make a Marine EFI code tool for less than $1.00 >
Old 08-23-2005 | 10:09 AM
Dave_N's Avatar
Default Re: Make a Marine EFI code tool for less than $1.00
Blake,
If it has the 10pin Data Link Connector (like the one shown in the picture above), it should work.
Dave
Dave_N is offline
Old 08-23-2005 | 11:12 AM
Frequency's Avatar
Dave,
How about MEFI 4 systems. If it works, are the error codes the same?
Greg
Frequency is offline
Old 08-23-2005 | 11:54 AM
29KILROY's Avatar
Dave can you please PM me!
29KILROY is offline
Old 08-23-2005 | 02:37 PM
Dave_N's Avatar
Frequency,
It will work on MEFI4 systems. The codes are the same for the most part, but MEFI4 systems can have multiple sub-codes under the same number that can differ depending on the engine (see example list below - from Volvo 8.1 ).
Kilroy,
You have a PM.
Dave
Attached Thumbnails Make a Marine EFI code tool for less than alt=.00-mefi4codes.jpg
Dave_N is offline
Old 08-23-2005 | 02:47 PM
Airpacker's Avatar
Do you know the pn for the connector you used?
Airpacker is offline
Old 08-23-2005 | 03:16 PM
Dave_N's Avatar
The connector is a Packard "Mertri-Pack" 150 series sealed 10 pin male connector. In addition to the connector body you will need the TPA (grey thing that clips to the top), terminals, seals, and (optional) plugs.
Info on Metri-pack connectors:
http://www.powerandsignal.com/IDC/Pr...MetriPack.aspx
Click on "2003-04 Global Connection Systems Catalog -- Metri-Pack 150"
Dave
Dave_N is offline
Old 09-06-2005 | 12:45 PM
Originally Posted by Dave_N
Blake,
Dave
Dave,
I am having a hard time finding the DLC connector. I have found the transom harness connector (10pin) and the CAN connector.
Is it located near the distributor or ECM? this is on a 2003 mercruiser 5.7L vortec
Thanks,
Blake
bbrocato is offline
Old 09-06-2005 | 01:33 PM
Dave_N's Avatar
Your engine has an ECM 555 controller. This trick will not work on PCM or ECM 555 systems. You will need a scan tool or smartcraft system display to read faults.
Dave
Dave_N is offline
Old 09-06-2005 | 02:49 PM
does this also mean I can't set the timing unless I have a scan tool?
Blake
bbrocato is offline
Old 09-06-2005 | 10:08 PM
Dave_N's Avatar
Blake,
You can't set the timing at all. Base timing is controlled by the computer and is not adjustable. You can loosen and turn the distributor, but it only aligns/misaligns the rotor with the distributor cap, it does not change the timing.
Dave
Dave_N is offline
