XR ITS Rebuild Step by Step >
Old 08-15-2007 | 06:19 PM
191 Installing prop shaft
192 Insert on prop shaft to protect seals
193 Same
Attached Thumbnails XR ITS Rebuild Step by Step-pict0191.jpg   XR ITS Rebuild Step by Step-pict0192.jpg   XR ITS Rebuild Step by Step-pict0193.jpg
John the Drive Man is offline
Old 08-15-2007 | 06:20 PM
194 Installing carrier
195 Positioning carrier
196 Placing tab washer
Attached Thumbnails XR ITS Rebuild Step by Step-pict0194.jpg   XR ITS Rebuild Step by Step-pict0195.jpg   XR ITS Rebuild Step by Step-pict0196.jpg
Old 08-15-2007 | 06:22 PM
197 Shows tab washer
198 Ready to install carrier nut
199 same
Attached Thumbnails XR ITS Rebuild Step by Step-pict0197.jpg   XR ITS Rebuild Step by Step-pict0198.jpg   XR ITS Rebuild Step by Step-pict0199.jpg
Old 08-15-2007 | 06:24 PM
200 Installing nut
201 Same
202 Same
Attached Thumbnails XR ITS Rebuild Step by Step-pict0200.jpg   XR ITS Rebuild Step by Step-pict0201.jpg   XR ITS Rebuild Step by Step-pict0202.jpg
Old 08-15-2007 | 06:25 PM
203 Tightening nut
204 Setting prop shaft load
205 Checking
Attached Thumbnails XR ITS Rebuild Step by Step-pict0203.jpg   XR ITS Rebuild Step by Step-pict0204.jpg   XR ITS Rebuild Step by Step-pict0205.jpg
Old 08-15-2007 | 06:27 PM
206 Locking nut with tab
207 removing set-up adapter plate
208 Same
Attached Thumbnails XR ITS Rebuild Step by Step-pict0206.jpg   XR ITS Rebuild Step by Step-pict0207.jpg   XR ITS Rebuild Step by Step-pict0208.jpg
Old 08-15-2007 | 06:29 PM
209 Plate removed
210 Installing O rings
211 Same
Attached Thumbnails XR ITS Rebuild Step by Step-pict0209.jpg   XR ITS Rebuild Step by Step-pict0210.jpg   XR ITS Rebuild Step by Step-pict0211.jpg
Old 08-15-2007 | 06:34 PM
212 Installing O rings
214 Installing upper housing
215 Same
Attached Thumbnails XR ITS Rebuild Step by Step-pict0212.jpg   XR ITS Rebuild Step by Step-pict0214.jpg   XR ITS Rebuild Step by Step-pict0215.jpg
Old 08-15-2007 | 06:35 PM
216 Installing mounting hardware
217 Placing of thrust washer
218 Same
Attached Thumbnails XR ITS Rebuild Step by Step-pict0216.jpg   XR ITS Rebuild Step by Step-pict0217.jpg   XR ITS Rebuild Step by Step-pict0218.jpg
Old 08-15-2007 | 06:37 PM
219 Pre-lubing thrust bearings
220 Installing shift shaft seal
221 Pictures of parts for upper housing
Attached Thumbnails XR ITS Rebuild Step by Step-pict0219.jpg   XR ITS Rebuild Step by Step-pict0220.jpg   XR ITS Rebuild Step by Step-pict0221.jpg
