XR ITS Rebuild Step by Step >
Old 08-15-2007 | 06:02 PM
Default XR ITS Rebuild Step by Step
155 Making sure housings are clean
156 Installing shims
157 Installing race cup pinion
Attached Thumbnails XR ITS Rebuild Step by Step-pict0156.jpg   XR ITS Rebuild Step by Step-pict0155.jpg   XR ITS Rebuild Step by Step-pict0157.jpg
John the Drive Man is offline
Old 08-15-2007 | 06:03 PM
158 Installing race cup prop shaft
159 Same
160 Same
Attached Thumbnails XR ITS Rebuild Step by Step-pict0158.jpg   XR ITS Rebuild Step by Step-pict0159.jpg   XR ITS Rebuild Step by Step-pict0160.jpg
Old 08-15-2007 | 06:04 PM
161 Installing pinion needle bearings
163 Needle bearings installed
164 Placement of pinion gear
Attached Thumbnails XR ITS Rebuild Step by Step-pict0161.jpg   XR ITS Rebuild Step by Step-pict0163.jpg   XR ITS Rebuild Step by Step-pict0164.jpg
Old 08-15-2007 | 06:06 PM
165 Placement of pinion gear
166 Preparing pinion shaft for installation
167 Same
Attached Thumbnails XR ITS Rebuild Step by Step-pict0165.jpg   XR ITS Rebuild Step by Step-pict0166.jpg   XR ITS Rebuild Step by Step-pict0167.jpg
Old 08-15-2007 | 06:08 PM
168 Installing pinion shaft
169 Installing pinion Screw
170 Gear and pinion location
Attached Thumbnails XR ITS Rebuild Step by Step-pict0168.jpg   XR ITS Rebuild Step by Step-pict0169.jpg   XR ITS Rebuild Step by Step-pict0170.jpg
Old 08-15-2007 | 06:09 PM
171 Certificates: Certified MerCruiser Master Techician
173 Installing Pinion shims
174 Same
Attached Thumbnails XR ITS Rebuild Step by Step-pict0171.jpg   XR ITS Rebuild Step by Step-pict0173.jpg   XR ITS Rebuild Step by Step-pict0174.jpg
Old 08-15-2007 | 06:11 PM
175 Installed retainer plate
176 Same
177 Same
Attached Thumbnails XR ITS Rebuild Step by Step-pict0175.jpg   XR ITS Rebuild Step by Step-pict0176.jpg   XR ITS Rebuild Step by Step-pict0177.jpg
Old 08-15-2007 | 06:12 PM
178 Installing pre-load shims
179 Same
180 Torque-ing pre-load plate
Attached Thumbnails XR ITS Rebuild Step by Step-pict0178.jpg   XR ITS Rebuild Step by Step-pict0179.jpg   XR ITS Rebuild Step by Step-pict0180.jpg
Old 08-15-2007 | 06:13 PM
181 Installing forward bearing cup
182 Pinion gauging tool installed
183Checking Pinion Height
Attached Thumbnails XR ITS Rebuild Step by Step-pict0181.jpg   XR ITS Rebuild Step by Step-pict0182.jpg   XR ITS Rebuild Step by Step-pict0183.jpg
Old 08-15-2007 | 06:15 PM
184 Checking Pinion Height
185 Pinion and gear in proper location
190 Installing prop shaft
Attached Thumbnails XR ITS Rebuild Step by Step-pict0184.jpg   XR ITS Rebuild Step by Step-pict0185.jpg   XR ITS Rebuild Step by Step-pict0190.jpg
