Kiekaffer Trim Tab Template >
Old 12-30-2007 | 04:59 PM
Enforcer2's Avatar
From: Ocean Pines, Maryland. Wish I was at MANGOS in MIAMI!
Default Kiekaffer Trim Tab Template
Can any one send me a template for mounting the 280 Kiekaffer tabs ???
Enforcer2 is offline
Old 12-31-2007 | 07:39 PM
You can make your own with some heavy paper, just tape in place push where the mounting holes are with some chalk on your finger cut edges to shape and its done. Put it in place 3/4" above the runing surface, mark your hole locations. Then you need to drill the holes at 90 in all directions on the transom. To do that, use a 6" x 6" sq flat pc of 3/4" ply screw a blk iron floor flange to it, tread in a 6" long 3/8" gas pipe at 90 to the block. Use a 24" long 3/8" drill, hold the block flat against the transom, and you have a hole guide at 90 in all directions with no drill press. If yor centers are on the money the studs on the K-plane slide right through the transom thickness for back washers and nuts. Worked for me!
27 MAGNUM is offline
Old 01-01-2008 | 10:11 AM
Enforcer2's Avatar
Thanks 27 Magnum
Old 01-01-2008 | 12:01 PM
got a pic?
open87 is offline
Old 01-01-2008 | 02:16 PM
Enforcer2, I have some templates your asking about. PM me with address.
MOBILEMERCMAN is offline
Old 01-02-2008 | 09:08 AM
Enforcer2's Avatar
Thank you sir, PM sent
Old 01-02-2008 | 06:59 PM
Originally Posted by open72
got a pic?
Here is the pic, it worked great for me all the studs went in like butter, every hole was at 90 and the template I made off the part was easy and the hole centers where money.
Old 01-02-2008 | 07:03 PM
Tony, mailman has it.
Old 01-02-2008 | 10:39 PM
Enforcer2's Avatar
Okay thanks again guys!!
Old 01-04-2008 | 10:50 PM
sunchaser796's Avatar
Magnum27 has had to learn the hard way when it comes to doing work on his magnum. I have seen the pics of the boat and so far he has done a wonderful job on it. I rig boats for a living and even I would'nt attempt to do some of the work hes done. When he does complete the magnum it will be one of the finest magnums around. Congrat to Magnum27
sunchaser796 is offline
