High Idle
Old 01-13-2008 | 12:50 PM
Default High Idle
I have a 28 Skater w /2005 250xs's,
After starting both moters cold within 5 min. or less the right motors idle runs up to about 1500 RPM and stays there until you shift into gear. Than it drops to a normal idle of 600 RPM. Put it in neutral it goes back up. I was told it was the T.P.S , so I switched it from the good motor. Problem was still there, and left motor still ran fine. So before I destroy the lower unit can any one HELP.
Frank Galasso is offline
Old 01-13-2008 | 05:11 PM
Air leak?
Ruaraidh is offline
Old 01-13-2008 | 05:17 PM
Is the cable adjusted properly? Is the lash in the cable allowing the idle to rise?
MOBILEMERCMAN is offline
Old 02-07-2008 | 08:23 AM
are the tps's set correctly....should find someone that can ddt it and see if it is set up or just out of adjustment.....cuase if it is an air leak it could cause some really serious damage..Ed
Darkspoilerzx is offline
Old 02-15-2008 | 06:58 PM
Poker&Run's Avatar
Sounds to me like you comp is keeping the motor in the cold start mode. Leak in the fuel rail can cause the same prob. Might check tire valve like fitting close to the water neck on the fuel rail to see if there is a slight leak.
Poker&Run is offline
Here's Johnny
11
09-25-2008 02:41 PM
Mrs T
7
05-29-2007 08:42 PM
RedDog382
13
06-14-2005 08:45 AM
Perfectmix
12
10-21-2004 08:32 PM
kaamacat
16
10-10-2002 06:40 PM
