smartcraft retrofit
That is some cool stuff Jeff. The nice thing however with the Merc stuff is that you can integrate it into your GPS system for one display for your guages and GPS. While this is certainly a step in that direction I think that they are not doing that, or am I missing something? It would also be nice to have it as the same "standard" as the Merc Smartcraft so that you can still use the analog read outs like Gaffrig makes.
Jon
Jon
Put your best foot forward!
They do have a GPS input as well. One problem I was considering was, how the visibility of the dash is in the sunlight. The data logging would be nice too. Unfortunately it would have to separate from the Merc stuff. I may be getting a little off track but MSD sells the stand alone Mefi4 with software so you can do your tuning as well.
Jeff
Jeff
Jeff I am not saying GPS into tha unit. I am saying that unit giving info to the GPS. You can then show your Tach, Fuel, temp and so on on your GPS screen.
Jon
Jon
Does that mean you have a functioning unit? What are you displaying for info? what screen(s) did you use? Cost?
may want to contact faria corp. they have beem working on alot of engine/vessel monitoring systems
http://faria-instruments.com/engine_monitoring.php
I have a unit that I have functioning on a bench. The boat is just the next step but there is no reason that it will not work well. What you can display depends on what you are using for your display. Each GPS unit is different. If you go with a specialized display then you can display just about anything you want even have touch screen stuff to turn on lights, bilge pumps and so on.
