quick upholstery question
I need to drill through some padded upholstery. Anyone have a tech tip on how not to ball up the padding while drilling through it? Thanks for any suggestions.
Poke a hole with a ice pick or something and use a rubber grommet or if its a small drill bit use the plastic tube from a bic pen. Good luck.
Sometimes running the drill backwards will wear a hole
without grabbing. Needs to be a really sharp bit. Used that trick on side panels. |
how do you repair the hole in the vinyl afterwards?
| All times are GMT -5. The time now is 07:19 AM. |
