bbc mech fuel pump
Old 07-15-2008 | 10:58 PM
Default bbc mech fuel pump
what are you guys running ?,
dmaxx3500 is offline
Old 07-15-2008 | 11:48 PM
BY U BOY's Avatar
I'm running the Holley 130 with regulator.
BY U BOY is offline
Old 07-16-2008 | 12:35 AM
are they marines?with the vent? or car pumps
Old 08-01-2008 | 07:00 AM
fuel pumps buy race pump with there reg only 15 lb push rod pressure and the simplest install I have ever done (fittings on top not bottom) and has the most flow I have seen http://www.racepumps.com/index.html
Last edited by eliminatethis; 08-01-2008 at 07:21 AM. Reason: better discription and link
eliminatethis is offline
Old 08-01-2008 | 07:14 AM
I also ran a bleed off # return to tank line they said I did not need it but I liked the idea of cooler fuel and I seem to worry about the ethinol seperating from the gas this may help stir it up but I have no facts just what I here at the ramp and parts store
Old 08-01-2008 | 09:14 AM
That looks sweet.
But I do not see a outlet for the vent tube?
1BIGJIM is offline
Old 08-01-2008 | 09:25 AM
Registered User
There's no diaphragm so there's no need for one. The diaphragm is like a balloon- it can't have pressure on the atmosphere side or it won't pump- so, it needs a vent. The only reason the vent tube is required bu USCG is if the diaphragm ruptures, the fuel will be contained. If a seal failed inside of a positive displacement pump, fuel wouldn't leak.
Example- USCG listed electric fuel pumps don't have vents.
Chris Sunkin is offline
Old 08-01-2008 | 09:57 AM
Have for sale Holley 170 gph.
Currently use the new Holley black billet pumps:
Big Block Chevy 200+ GPH UHP Series - Marine
Part #: 12-454-40
Due
Dueclaws is offline
Old 08-01-2008 | 11:34 AM
they do have a vent tube on there reg for my application on some apps. its used as a vac. ref.
Old 08-05-2008 | 01:59 AM
Nice
formula 382 sr-1 is offline
