Originally Posted by scarab31
(Post 2733906)
What would the 496 manifolds and risers provide???? I've heard that they will improve mid-range torque through better exhaust flow efficiency??? You would also drop a bunch of weight if you had the aluminum 496 manifolds. I'm curious since I have stock 454 mags in my Scarab and would like to try and squeeze 40 to 50 hosepower potentially out of each engine.
The 496 Manifolds are actually pretty nice, seperate runners into a big 4" riser |
If I take it easy, the alpha's might last. If not, it is easier to get the insurance to replace outdrives than engines. I think I will just change the exhaust tips from 3" to 4" this offseason.
Bill |
Originally Posted by wfyehl
(Post 2736161)
Bill |
Originally Posted by Full Force
(Post 2736169)
Not when the insurance finds out they have more HP going through them then they are supposed to, I know how Tom has smoked Bravos on his Rogue, I will say the Alpha has no chance on that boat with bigger HP.
Bill |
(Post 2737248)
How will the insurance co. find out that there is more horsepower? Will they dyno the engines for me? I plan on keeping it stock looking (keep the q-jet, 496 exhaust manifolds, not sure which cam or intake).
Bill |
Good to hear as I already have the 496 aluminum manifolds and risers. Just need to polish the risers and complete the install. What did you use for your shift cables mounting? I aso have remote mounted oil filters off of the stock manifolds too.
(Post 2734092)
I am running the 496 stuff on mine, I make about 450 hp, Iw as told by alot of people that they support up to 500-550 hp easily.
(Post 2742330)
http://i36.photobucket.com/albums/e4...g/113_8265.jpg |
| All times are GMT -5. The time now is 01:21 AM. |
