lightning
Originally Posted by skaterdave
(Post 2724601)
you might wanna check out http://www.boatheaders.com/index.htm
they make headers for small block that are true water jackets big tube headers and are alot less expensive than the rest. (granted this was a long time ago) I ultimately moved to the powerflows because lightning just wasn't delivering the small block product- my other lightning product experiences have been very good. At the time I went with the powerflows the SS marines had a clamping issue. The ability to slightly move the elbow is kinda neat it seems like the older units had a single clamp and the picture here it looks like its a double clamp setup now. Any kind of tube setup is going to give better top end performance than a manifold but realistically it may not be worth the bucks if its your only modification- you are back to $ again. Question- Baja 280- what have you done to your small block ? The expense of tube headers may not buy you anything over a manifold if this is your only mod or your mod is a low end midrange build Uncle Dave Laveycraft 2750 -710 Laveycraft 20.8 Sebring |
Originally Posted by Uncle Dave
(Post 2724666)
The ability to slightly move the elbow is kinda neat it seems like the older units had a single clamp and the picture here it looks like its a double clamp setup now. Uncle Dave Laveycraft 2750 -710 Laveycraft 20.8 Sebring |
Imco pict
2 Attachment(s)
Heres a pict I snapped in the shop this morning of an Imco BB setup which is very similar to the SB setup.
The boat its is my friend Big "D's" 22 ft Cole Superhawk and its getting a hatch repair so I snapped a pict for you guys. Although I really like and can recommend the Imcos if SS marine has the clamping issue fixed- the ability to rotate the elbow makes installation a helluva lot easier. The shot of the tubes is my new Ilmor 710. You can check out the build in the Laveycraft forum. The boats Killer. Uncle Dave Laveycraft 2750 -710 Laveycraft 20.8 Sebring |
3 Attachment(s)
I love the Stainless Marine...gained 2 mph 150-200 rpm's.....
(Post 2724666)
I waited about a year for lightning to actually deliver the small block headers because I didnt want to go with a manifold type unit
(granted this was a long time ago) I ultimately moved to the powerflows because lightning just wasn't delivering the small block product- my other lightning product experiences have been very good. At the time I went with the powerflows the SS marines had a clamping issue. The ability to slightly move the elbow is kinda neat it seems like the older units had a single clamp and the picture here it looks like its a double clamp setup now. Any kind of tube setup is going to give better top end performance than a manifold but realistically it may not be worth the bucks if its your only modification- you are back to $ again. Question- Baja 280- what have you done to your small block ? The expense of tube headers may not buy you anything over a manifold if this is your only mod or your mod is a low end midrange build Uncle Dave Laveycraft 2750 -710 Laveycraft 20.8 Sebring The engines are out, Just refinished the boat 6 months ago, engines are stock 260's and the boat runs about 55. Would like to reach the 70 mark if I could |
Well if the Engines are out - Nows the time.
Does your boat have external steering? (doubting it) Bad news- thats a big delta. Good news we can get you there. Exhaust is the first thing you've gotta do- but take a look at what it bought Spillman- 1-2. What's your budget? Uncle Dave Laveycraft 2750 -710 Laveycraft 20.8 Sebring |
sb exhaust
(Post 2725088)
Does your boat have external steering? (doubting it) Bad news- thats a big delta. Good news we can get you there. Exhaust is the first thing you've gotta do- but take a look at what it bought Spillman- 1-2. What's your budget? Uncle Dave Laveycraft 2750 -710 Laveycraft 20.8 Sebring Back to the Stainless Marine; Installed I paid $4,500 for both motors- alot of $$ for 2mph! But, like I said I had to replace them & I would do it again all things considered- weight savings, sound & slight power increase. btw, Uncle Dave, what external steering wouldyou rec. for my boat? |
Wow.... I just wanted a little more HP. Didn't know I needed external steering.
What do I do? Please give me some hints Uncle Dave... Need to keep the Budget below 12K. |
Oh Ya. Forgot to mention. The boat only has Alpha drives.
i'm running stainless marine with dry pipes on procharged 434's.made 725hp with drag car headers on the dyno. bolted my manifolds on to see how much i would lose . i gained 15hp !
| All times are GMT -5. The time now is 08:34 AM. |
