Docking light - Mfg Rec and Installation tips - Thanks >
Old 11-04-2008 | 11:22 AM
HiZ
Default Docking light - Mfg Rec and Installation tips - Thanks
Ok I am going to put in some Docking lights over the winter.
Questions are:
What Brand/Brands have you tried out there Pro's Con's
I was looking at some on a friends wake board boat manufactured by Innovative Lighting - any comments?
I have not seen them in action.....
Also are there any tips for installation of these on my boat.
312 Stinger
Thank you........
HiZ is offline
Old 11-04-2008 | 11:31 AM
HiZ
Docking, Hull, Back-up Lights
Product Number: 580 Series
Sold as a Pair
Operates 12 Volt DC Systems
50 Watt Halogen Lamp
Draws 4 Amps Each
Sealed Built-in Rear Heat Sink
Thermal Insulated Wires
Pyrex Optical Lens
Spring Loaded Lamp Assembly
Removable Lens Cover
Water Tight Gaskets Included
Patent #D472654
7.60" x 4.15" x 3.75"
Case Color: *
--Select-- Black White Mirror Polished (add'l $10.00)
Qty:
HiZ is offline
Old 11-04-2008 | 11:33 AM
HiZ
http://www.innovativelight.com/index...1567&iFileNo=3
HiZ is offline
Old 11-07-2008 | 06:53 AM
Audiofn's Avatar
Charter Member #232
Nice site HIZ. Thanks.
Put your best foot forward!
Audiofn is offline
Old 11-11-2008 | 06:44 PM
I installed them on my boat,no problems and they work good
Attached Thumbnails Docking light - Mfg Rec and Installation tips - Thanks-lights-001.jpg   Docking light - Mfg Rec and Installation tips - Thanks-d-010.jpg
boatnt is offline
Old 11-11-2008 | 08:57 PM
Boatnt, Did You Put Them In Yourself Or Did You Pay To Have Them Put In. Is That The Same Powerquest That Is Forsale On Speedwake. It Looks Great..
PQCRAZY is offline
Old 11-13-2008 | 06:33 AM
Try Eddie Marine. Powder coat colors available too.
ROTAX454 is offline
Old 01-31-2009 | 04:49 PM
HiZ
When you are under power at night is there any benifit or just a docking thing?
What is the range/brightness for them I guess is the question
HiZ is offline
Old 02-01-2009 | 01:54 AM
It is illegal to run with them on except for docking. They blind other people and other boats can't see your nav lights. They really don't do much anyway on the water. The light just reflects off.
I just carry a 2 million CP handheld spotlight in the boat.
Griff is offline
Old 02-02-2009 | 04:23 AM
HiZ
Roger that, sorry reading my post yeah.
I meant when you are under power as in when you are coming into harbors/shore etc. I keep my boat in a tight harbor with an entrance that is 5 ft that is 12 ft wide, then jumps up to a 1-2 ft shelf!
Like you say yes, handheld, are they able to pics up things from a distance or is the handheld just as well?
HiZ is offline
