help with water in cylinder >
Old 11-10-2008 | 05:06 PM
Default help with water in cylinder
I took my 24 pantera out last weekend and somehow got water in one of the cylinders.
I launched on a river so it had a long idle maybe 10 min and when i went to open it up it started missing, it sometimes does this but usually clears up within 30secs. This time it did not clear up so I got it back home and pulled the port aft plug(not sure about cyl #)and it had condensation on it. checked the oil and no milkshake. I decided to replace all the plugs thinking it got in the intake when I washed it or something so I started it on the hose and it sounded fine. I took it back out and it was still missing, I pulled the plug and there was water on it. Got back to the house and checked the oil, it was a milkshake now.
anyone have any idea of what may be wrong?
I am obv going to have to tear down the engine and rebuild now but I was wondering if this is a typical failure in marine engines.
it is a 454 330 with emi thunder exhaust
thanks in advance
beck427 is offline
Old 11-10-2008 | 05:12 PM
Steve_H
how many hours on the motor? first thing i would check is the head gasket on that side.
Old 11-10-2008 | 08:05 PM
Ditto
AO31 is offline
Old 11-10-2008 | 09:39 PM
johnnyboatman's Avatar
mine did it was a header leaking
johnnyboatman is offline
Old 11-11-2008 | 06:51 AM
Registered User
I would pressure check the headers and do a compression check and a leak down check.
clpbs is offline
Old 11-11-2008 | 09:19 AM
Exhaust
djtalon is offline
dcroghan
4
10-20-2007 03:44 AM
Island Time
5
03-20-2006 06:09 PM
NetGain
8
08-02-2005 09:34 AM
ApachePete
9
02-05-2003 09:10 PM
