square heads or oval on 500hp >
Old 01-10-2009 | 03:52 PM
How would the 454 R work on a mild 454 that dyno at 460 hp at 5400 ? Have stock alum Merc dual planes with Eldebrock 750 Marine carbs. Would low end suck? Most of time cruise at 3400-3800 rpm. Has good hole shot now.
team Tickfaw is offline
Old 01-10-2009 | 07:13 PM
Rookie's Avatar
Weiand Stealth, a dual plane manifold that will run in the higher rpm range like having a single plane. best of both worlds.
I had the floors on my rectangle port intake welded up 1/4" to match my wedged heads to increase velocity. my 468's made 590HP with this manifold.
http://store.summitracing.com/partde...8&autoview=sku
Rookie is offline
Old 01-10-2009 | 07:55 PM
What cam, head and exhaust?
jeff1000man is offline
Old 01-10-2009 | 07:57 PM
Interesting. Looks like the same of the Merc intake. I know that inside designs differ. Looks alittle taller than the Merc. Thanks for the info.
Old 01-11-2009 | 02:08 AM
Rookie's Avatar
The Weiand Stealth was THE intake that was used back in the day when A and B class engines were limited to dual plane manifolds.
Cam ultradyne in. 252 ex 264 @ duration @ 0.50, lift 0.630 in., 0.630 ex
Heads: JimV (Valako race heads) fully ported and wedged Merlin rectangle iron heads 2.30" in. 1.89" ex. (most improtant ingrediant to the build). 9.6:1 forged JE SRP pistons, Holley Barry Grant 750's.(I need 850's to make 620HP) Stainless Marine exhaust.
570HP @ 5500, 590HP @ 6250
Rookie is offline
fastlane40
7
06-01-2008 04:55 AM
FAST ENOUGH
Drives and Lower Units
15
10-03-2007 03:41 PM
BOATING ON A BUDGET
11
02-20-2005 09:45 PM
captndonzi
8
01-09-2005 09:16 AM
1Boatnut
19
01-23-2003 04:14 PM
