comp cam ?
Old 12-31-2008 | 04:35 PM
Default comp cam ?
Im building a 383 stroker. The heads are summit racing vortec with 202in 160ex . Scat 9000 383 crank. Scat I beam 6" rods. SRP forged pistons. Edelbrock RPM air gap intake. Edelbrock 600 cfm carb. Cloyes double roller hex-a-jus timing gear and chain. Full roller rockers. The cam I'm going to run is a comp cam xm276hr. This is a roller cam . [email protected]" lift in.224 ex.230 lobe sep.112 lift in.503 ex.510 The description says it's good for a jet boat with a or b impeller. This engine will used in a I/O application. I was just wanting to known if anyone has ran this cam in a I/O and had any issuse. Any fed back would be appreciated
powerplay230 is offline
Old 01-07-2009 | 10:37 PM
Was really hoping to see some responses here as I'm going to be building a few very similar motors for mine..... Have you called Comp Cams? I've heard most of these manufacturers have pretty good tech lines to help out.
ttrm007 is offline
Old 01-09-2009 | 04:13 PM
I've talked to the tech guys at comp cams and they didnt think I'd have any problems and i don't either. I really thought there would of been alot more guys out there that had done small block 350 builds that might of used this cam.
Old 01-09-2009 | 08:50 PM
We used Bullet Racing Cams in our 383's specs were 223/ 231 530/548 on a 110 center line . They made 425 on the dyno but we used would sportsman II heads and a Edelbrock 750 cfm.
formula 382 sr-1 is offline
ak
Swap Shop
0
12-17-2008 05:59 AM
badluck
5
02-04-2007 06:40 PM
QUIKDECISION
13
04-18-2006 06:20 AM
danielthelen
19
08-22-2003 03:48 PM
BAJA WILL
5
07-21-2003 01:16 PM
