intake ?
Old 04-25-2009 | 11:28 AM
Default intake ?
Hi all recently bought hp500 intake carb package from hardin marine it is part# 620-54000 my engine biulder is telling my the the ports are way to big or sumthing and the intake is no good can someone tell me if this was a good buy or what. O ya its in a 454 mag rec ports.
burninbridges236 is offline
Old 04-25-2009 | 11:53 AM
A little big for a 454 mag, but it will work fine. You may loose a little torque in the low and midrange rpms.
Griff is offline
Old 04-25-2009 | 02:08 PM
AIR TIME's Avatar
have the builder match port the two. I hope you are up grading the cam to go with the kit other wise the carb is to big also. stock 454 365mag 750 carb not a 800 or 830.
AIR TIME is offline
Old 04-25-2009 | 02:09 PM
AIR TIME's Avatar
true
AIR TIME is offline
Old 04-25-2009 | 08:05 PM
Yes yes i got a hydro roller cam 283 290 223 250 at .50 .566 .575 114 sep hp 500 intake 750cfm holly carb roller rockers lifters msd blue box ign kit on fresh rebuild o and imco thunper manifolds. Any est on hp and also should the engine builder gas match heads and intake. THANKS ALL
Old 04-26-2009 | 10:56 AM
Throttle Fever's Avatar
You have to look at what you are going to do with the engine boat combo. Your builder is right. Unless you are going to be running at WOT most of the time. Most people over cam and carb there motors, then run it in the 2500 to 3500 rpm and wonder why its a pig. I have dynoed alot of manifolds. I have made more HP and torque with simple dual plane manifold in alot of applications. If you are going to at WOT (4500@ up) the hp 500 intake will be fine. For low end it will hurt you. It is all up to you and what you want to do with your set up.
Throttle Fever is offline
Old 04-26-2009 | 11:07 AM
Who is your engine builder? Local?
ittledoo is offline
Old 04-26-2009 | 12:07 PM
I would talk to your builder to see if he can weld up the floors in your helads and intake. This might not be cheap depending what area your in however well worth the time and expense. Even 540+ CI's like the smaller ports. It helps make a lot of torque. Don't be real disapointed however you may want to consider selling what you have and starting over. I have always been a big fan of oval port heads as long as your not going over .600 lift and 5600 rpms. Also unless you have real big cubic inches.
Good luck and keep us posted.
getrdunn is offline
Old 04-26-2009 | 12:45 PM
The HP500/ Dart intake is one that does not loose as much power down in the lower rpms as most other single planes. I'm sure thats why Merc used it. I would just run it since you already have it.
Griff is offline
Old 04-26-2009 | 05:27 PM
Hey hey how are you ready for summer but it is runion engines in decatur he does alot of racing engines he really helped me. On the other note i think im just going to keep the intake and try it out i run alot at high rpm but also want to cruise and sometimes tube so i hope it works out.
