Best stereo battery?
Old 04-29-2009 | 11:47 AM
Has anyone ever had their alternator re-wound? I was talking with a car stereo shop yesterday and they said Im probably not fully charging the batteries with a stock alternator. They suggested a rewind to 225 amps (is stock 140 amps?).
Powerquest_Baby!! is offline
Old 04-29-2009 | 12:05 PM
Originally Posted by n20michael
No Worries!, I AM actually looking for a pair of Optima's, and yes, they aint cheap!, its just a thought, but, how about yanking the batteries out of either a buddies boat, or maybe even your tow vehicle?, be a bit of a pain in the arse, BUT, it would be A LOT worse to go out and drop a bunch of coin on 2,4, or 6 new batteries and find out that WASN'T the problem. I also agree with an earlier post, get the batteries load tested, you can use a volt gauge to check the batteries, but, you really need to use a load tester to see if they are any good, I too have seen batteries read WELL over 12 volts on a volt gauge that weren't any good.
Instead of a generator?, if you haven't already?, how about shore power, or at least a good healthy on board battery charger, at least then when your in a marina or anywhere near power you could plug the boat in and have tunes without worrying about the batteries going flat.
Good Luck!
Michael
Yes I do have shore power and a charger but when you have the boat in the water for 20 mins after being at home on the charger and the stereo cuts in and out 20 mins into the day I know they have power. I took the blue tops into Interstate (they are the Optima dealer) and they load test perfect. Again I think they are designed to give a small steady current and not a but load that are needed to run the amps under high volume.
I talked to the starter and alternator shop here in town (Omaha, NE) and they said they can not increase the charge output on the alternator. I am not sure if I just got the stupid guy or if they really cant do it. I have the same problem with fresh batteries as I do with batteries I have been running all day. I think my alternator is a Mando and has an internal regulator.
Powerquest - if you fin someone who can "hot rod" your alternator let me know, but again I think it is not a charging issue I think it is the battery (s).
baja_brian is offline
Old 04-29-2009 | 03:52 PM
I have seen high output alternators, once again, they where for the "Car Stereo" kids who needed huge amperage to run there stuff, cant see why you couldn't have yours redone?, if not, I would suggest buying a higher output one, I know "Powermaster" make some pretty high Amp units, and there are other companies as well.
I have never seen your setup, so, PLEASE dont take offense, but, I know a pile of guys running systems very similiar to yours and are getting A LOT more than 20 Mins at high volume, but, I guess there is only so many things it can be?, like I said earlier I hate to see people throw "good money after bad". If you buy new [different] batteries and an alternator and the problem persists you are gonna be pretty PO'd!, and rightfully so.
If it was me, I think for the few minutes it would take, I would go back and have a really, really good look at the wiring, it doesn't take much when beating around in the waves for something to come loose [or worse "partially" loose] If it IS an intermittant problem and its on the power side, the extra couple of volts [and amps] that the alternator provides MIGHT be enough to overcome a bad connection, the loss of that power when on battery power, might not. Have a look at all the ground connections/power connection, distribution blocks, etc, if the wires are crimped or attached anywhere, make sure those connections are good, I wouldn't just have a quick look, take some time and go over all of it really well, if nothing else at least you can eliminate the idea of it being a wiring problem then. Coming from an automotive background I have seen others, and, experienced first hand how frustrating it can be to chase an electrical problem, I have seen people replace component after component to no avail, only to find a small crack, or partially corroded connection on a small "trigger" wire, or something silly like that. I feel your pain!
Michael
n20michael is offline
Old 04-29-2009 | 04:56 PM
First off, it cuts in and out with the boat on and off. I understand where Powerquest is coming from exactly. Secondly it will do it with fully charged batteries. I don’t want to come across rude but you have the same thoughts as everyone else. I said the wires have been check and re checked, amps and speakers have been swapped out. The problem appears to be at high volume the amps draw more power than the batteries like.
Old 04-29-2009 | 05:33 PM
GREAT!, sounds like you have it all figured out then, good luck!
Michael
Old 04-29-2009 | 07:01 PM
Micheal-
First off, the ultra high end car stereo kids are probably running Kinetic or similar stereo batteries. Upping the amp output on the alternator is waste. You also have to use a marine alternator that is spark protected.
His batteries are not going dead after 20 mins. They are just not able to handle the constant draw of power for more than 20 mins.
Brian-
I can't tell you for sure what will work, but I can tell you that I am running 2 amps for 1100rms watts off of one Interstate group 31/29M deep cycle battery and it handles it fine. The thing about regular batteries vs deep cycles is that regular starting batteries won't last if you run them up and down a lot.
I can also put you in touch with a friend of mine who does a lot of high end boat stereo installs here and at LOTO. I'm sure he would be able to lead you in the right direction.
Griff is offline
Old 04-29-2009 | 07:58 PM
GRIFF
NOPE, they where running either Optima or some other form of "Gell" battery, one fella had an Odyssey set up, but, most of them where using eiter red or yellow top Optima's, SEVERAL had aftermarket alternators, which according to them put out more Amperage than the stock ones, I am NO expert, but, I assumed it was done for a reason?
Brian
Good luck with the boat, hope you get it sorted out
Old 04-29-2009 | 08:20 PM
rchevelle71's Avatar
What you all are missing iks that it is fine when it s running, it is not the alternator, its the batteries!!!!
rchevelle71 is offline
Old 04-29-2009 | 08:49 PM
Audiofn's Avatar
Charter Member #232
You can not really compair car and marine. Marine has two alternators so you already have 280 amps in most twin aplications. You NEED to put a volt meter on the batteries and also the amps and see what your readings are.
Put your best foot forward!
Audiofn is offline
Old 04-29-2009 | 10:39 PM
Originally Posted by rchevelle71
What you all are missing is that it is fine when it s running, it is not the alternator, its the batteries!!!!
BUT if the batteries arent getting a full charge is it the batteries fault of the alternators? Obviously its the alternator. IF the batteries are getting a full charge and not holding it then it falls on the battery.
I understand what you are saying but when the engine is running the batteries are getting a constant recharge..The real test is when the engine is off.
