-   -   sloppy throttle control (https://www.offshoreonly.com/forums/do-yourself-boating-budget/208176-sloppy-throttle-control.html)
95CROWN 05-04-2009 06:17 PM
Hey, Ive got a 95 Crownline 225 CCR that has a really sloppy throttle control. The lever will move about an inch forward and backward when its locked in neutral. Are there any adjustments that can be made? Also, I had troubles starting the boat one time. I suspected it may be the neutral safety switch so i worked the throttle back and forth while hitting the starter and got it to fire. Any suggestions?
Boat Tech 05-05-2009 04:17 AM
http://www.offshoreonly.com/forums/g...y-shifter.html I'm not 100% sure of what shifter you have but this thread might help,Good luck.
