Fluid Help Please
Old 06-14-2009 | 06:27 PM
Default Fluid Help Please
I need to change the fluid in my Velvet Drive transmission? I read that I should us Type F or Type FA automatic transmission fluid, but (I almost hate to type this) I am not sure how to drain the old fluid? Could any show me were the plug is? About how many quarts will it take?
I also need to change the "gear oil in the out drive". What is the best gear oil and viscosity for the TRS drives?
What do you use for the trim tabs pumps? I need to change the fluid for my trim tabs as well.
Thanks for the help. Old boats don't come with owner manuals.
OhioRiverCigarett is offline
Old 06-14-2009 | 08:33 PM
Unscrew the hose from the fitting on the lower starboard side of the transmission.Then unscrew the fitting out of the tranny.It may have a spring, washer, and tube inside.The tube has a slot in it so when you reinstall have the slot facing down.Fill with dextron ll or type F transmission fluid through dipstick hole to full mark.After running check dipstick to see if you need to top off.You will want to use Mercury High Performance Gear Lube in the drive.4 quarts.In the trim tab pumps use your same transmission fluid.
picklenjim is offline
Old 06-15-2009 | 06:14 AM
Audiofn's Avatar
Charter Member #232
I have been told ONLY type F fluid on the tranny. Can be hard to find some times but that is what I use. I am going to take my oil changer pump and put the tube down the dip stick hole and suck it out. Should that work?
Put your best foot forward!
Audiofn is offline
Old 06-15-2009 | 06:15 AM
Audiofn's Avatar
Charter Member #232
I think it is 2 quarts per unit.
I use the Merc High performance lube for the drive.
Audiofn is offline
Old 06-15-2009 | 09:42 AM
Rookie's Avatar
The TRS drive holds 3 quarts itself, then what ever the resevoir holds. $600 later, don't ask me how I know.
Rookie is offline
Old 06-15-2009 | 01:19 PM
The quote I made on the type of trans fluid being dexron ll or type F for the velvet drive came right out of the Mercury manual #9.As far as sucking it out with a pump I've never tried it but I would think it would work as long as the hose seems to be going all the way to the bottom and you bring out a significant amount of fluid.
