need a little help again
Old 07-07-2009 | 11:07 AM
blue thunder's Avatar
I would go with an 3 blade aluminum michigan wheel round ear type prop. You are not push enough hp to worry about blade strength, plus alum is more forgiving.
blue thunder is offline
Old 07-07-2009 | 11:23 AM
ok thanks for all the help. i may order it this week some time.
bluez is offline
Old 07-07-2009 | 07:35 PM
Your welcome bluez. The rule of thumb on prop pitch is pitch it to achieve max rated rpm. Every inch of pitch is usually good for 200rpm. Just make sure your tach is accurate and the engine is tuned well before setting the pitch for WOT max rpm..
BT
Old 07-10-2009 | 11:39 AM
yeah i checked that today. it was off by 100 rpm. so now i have a tac. havent had time to order the prop yet.
bluez is offline
