Internal oil cooler leak
Old 07-11-2009 | 12:12 PM
Default Internal oil cooler leak
Anyone had problems with moisture getting in your oil from a leaky oil cooler? Been getting some moisture in the oil.
I think I narrowed it down! Haven't done a pressure check on the cooler yet, but the block is fine.
dslbrnr is offline
Old 07-11-2009 | 03:01 PM
You've got me thinking now. I found a soupy mess of oil in one of my 454's, but no sign of cracked block or blown head gasket, and the heads were new. I'll pressure check the heat exchanger.
bustedbrick is offline
Old 07-12-2009 | 11:12 AM
Let me know what you find.
dslbrnr is offline
Old 07-12-2009 | 12:26 PM
c_deezy's Avatar
Its not impossible. Pressure check your cooler and see what you find.
c_deezy is offline
Old 07-12-2009 | 06:36 PM
Default something worse
I pressurized the oil side to ~30psi and put it in a bucket, no bubbles anywhere after a minute or so. I'm back to head gasket and/or cracked head/block.
Good luck with finding the leak.
Randy
Old 07-12-2009 | 08:42 PM
paradigm shift's Avatar
Randy
Depending on exhaust type a riser gasket can cause moisture along with a cracked exhaust manifold. Just something else to check if you have not already.
paradigm shift is offline
Old 07-12-2009 | 10:00 PM
Thanks, I'll check this too. Bare block and heads are at the machine shop for pressure check and magnaflux. Randy
Old 07-13-2009 | 01:22 AM
Just wondering, how high can the water pressure rise in the cooler? Would the water pressure be higher then the oil pressure?
dslbrnr is offline
Old 07-13-2009 | 09:45 AM
Oil pressure will be higher than water pressure.
1BIGJIM is offline
