Autometer GPS directions suck! >
Old 07-25-2009 | 04:38 PM
Default Autometer GPS directions suck!
There really aren`t any directions now that I think about it. Just a diagram. It has two antenna/receiver and two 12v and ground connections.. one is a plug. No explanation on which to use. Thanx.
The wires on the Hardin GPS receiver are paper thin, actually really ridiculously thin.. Only way to make sure they don`t break off is to solder them IMOP.. which is what i did.
The receiver has a vessel ground.. I`m new to boats but how can there be a vessel ground on an all fiberglass vessel??
So after all that
I hooked up the gauge and it sweeps all the way to 10 (100mph gauge) then 7 then 0.. then 3 and stays there.
Trouble shooting states that if the gauge is stuck at 3 its in the "clear "position on the recall switch.
I don`t even have a recall switch hooked up!
What am I doing wrong? both 12V+ leads are hooked up (from GPS and gauge) along with 12v battery ground and white wire to white wire (from GPS to gauge)
ICDEDPPL is offline
Old 07-26-2009 | 08:24 AM
Thumbs down
I got it figured out .. only took half a day thanx to Autometer.
The wire labeled white (receiver/antenna) was actually the Lamp+ hook up for the light. Makes a big difference when your trying to hook up the GPS to a light connection
The sweeping and diagnosis are all wrong also.. and the 30 gauge Hardin Marine wiring didn`t help anything either. and the plug had to be cut off and rewired.
Thanx Autometer!
ICDEDPPL is offline
Old 07-26-2009 | 10:47 AM
U should of bought a GAFFRIG .
DareDevil is offline
Old 07-26-2009 | 04:11 PM
thats what i just oredered!
454Rea$onS is offline
Old 07-27-2009 | 09:19 AM
Gaffrig is almost twice the price.. Autometer is a local company plus they`ve been around a long time you`d think they do a better job..
ICDEDPPL is offline
Old 08-12-2009 | 09:10 AM
Now the gauge starts to sweep to 10.. then 7.. then 0 . then it reads the speed and starts all over again.
Of course I have no idea what this means as the instructions are 90% incorrect.
Autometer Marine site isn`t finished and has no info.. hopefully CP can help
ICDEDPPL is offline
