Missing RPM on 496
I would also check for guardian problems. If your water pressure drops for more than a few seconds you will get the guardian set which will put you back to %90 power. If it continues to have lower water pressure it will go to even less power. You should see/hear the alarm though when this happens. You can clear it usually by cycling the key a few times.
I have had this problem a few times and ended up getting some harnesses from whipple which prevent the code by showing a higher amount of pressure using a resistor.
