Stereo Pops When Triming
Old 09-19-2009 | 10:01 AM
There are resistors that you put on your trim pump...no ground issue, you can run grounds all day long,nothing is going to change. The Part number is #8M0034258 this is a Mercury Marine part you will need 2 and here is a picture, again you don't have to redo any of your wiring unless its just not done properly...
Keep us posted
26 REDLINE is offline
Old 12-18-2009 | 08:31 AM
try installing a stiffening cap on the power side of your amps, they are likely pulling too much power from the overall system!!! assuming of coarse your grounds are all ok...
adk61 is offline
