Boat Wiring
Old 09-18-2009 | 02:32 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Originally Posted by Velocity Vector
And good flat braided gounds to the engine and heads do not use battery cables for grounding but flat braided gounds work best.
curious as to why
I have use battery cable for my grounds
never thought to ground heads also
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 09-18-2009 | 04:41 PM
CPPerformance's Avatar
Yep we have several harness' to make your life a little easier when re-wiring not just your engine but the entire boat also. All harness' come with complete wiring diagrams to make it as simple as possible. You can see these diagrams on our website under Tech Support. Let us know if we can help!
http://www.cpperformance.com/SearchR...CategoryID=109
CPPerformance is offline
Old 09-27-2009 | 12:13 PM
monstaaa's Avatar
mercury harnesses are the best. they come in different lengths. . as for grounds as audio said tinned multi strand wire is best. as well use tinned ends or lugs. and crimp donot solder. and use adhesive lines shrink tube.
monstaaa is offline
Old 09-28-2009 | 06:27 AM
Audiofn's Avatar
Charter Member #232
Monstaaa: Solder is ok if you use solder with a low amount of Rosin. I tend to use silver solder as it has a low flow point and no rosin. It is expensive compared to other solders but works so much better. Rosin is an acid so if you do not get it off the wire over time it can cause more issues then a crimp.
Jon
Put your best foot forward!
Audiofn is offline
Old 09-28-2009 | 10:26 AM
littledcsrodshop's Avatar
Originally Posted by Rockfish71
So has anybody used these wiring harnesses ?? I was just about to order a engine harness last night & ran accross this & thought its definatly worth checking into since its $60.00 cheaper.. I am needing a 9 pin engine harness for a custom application (like the ones sold by both these vendors 6ft of wire, merc type cannon plug ect..) Anybody have any experiance with them ??
littledcsrodshop is offline
Old 09-28-2009 | 07:07 PM
Anybody ??
Old 09-28-2009 | 07:33 PM
MER Performance's Avatar
CPs Harnesses are made by the same person that makes them for myself, the harness for Whipples kits and so on, alot of us out there use this person. The harness also come in different lenghts. He also does custom fitted harness. But if you are only doing one boat, it will be $$$. Buy, it from CP, because you are not going to get dealer or WD pricing and he doesn't sell direct to the public.
MER Performance is offline
Old 09-28-2009 | 09:16 PM
Forgive my ignorance or any oversight but I'm a little confused are from ebasic power, or another vendor ?? CP's kit is $139.99 ish & the Ebasic kit is $79.99 ish.. I am looking at the 9 pin merc style plug with 6' of wire as they both have & appear to look pretty much the same & yeah I only need 1 kit as I am rigging a single.. Are you saying they come from the same mfg. ??
Thanks, Scott
Old 12-21-2010 | 06:47 PM
Thanks, Scott
Bump for a good thread and I have the same question as well, why are the harness at ebasicpower.com half the price compared to cpperformance? looks same to me....
http://bpi.ebasicpower.com/c/ALL6I/
Pokher Ace is offline
