Best hp cam for a stock 454 >
Old 01-07-2010 | 10:45 PM
Thanks for all the info guys. I'm buying marine parts for the boat. It is freezing here in New Jersey. 1 to 3 inches of snow expected tonight. Can't wait for spring.Now the boat sits.
89 Baja 250 is offline
Old 01-16-2010 | 10:28 PM
Question
Originally Posted by picklenjim
You may want to consider an intake manifold (dual plane) and carb change along with it to like a 750 holley.http://www.summitracing.com/parts/CCA-11-236-4/
What is a Dual plan manifold??
Does a high rise manifold do much for performance??
What is the stock CFM og a 454 magnum?? I assume around 500 CFM??
2Slow4me is offline
Old 02-25-2010 | 10:17 PM
currently building my stock 454 330 hp went to 9.5 to1 compression .60 over ,comp cam, had jet performance rejet the stock carb to stage 2 jets should push 400 to420 hp. all for the low low price of about 4 grand. now watch that alpha drive fry.
jbones98 is offline
Old 02-26-2010 | 01:05 AM
A DP manifold has a divider in it below where the carb bolts.
A higher rise manifold will help with air flow.
Stock carb cfm for all standard 454's and 502's is 750cfm.
Griff is offline
