Cam help
I just went through this last year. Use the double roller chain, roller cam button, new timing cover. The stamped steel cover has way to much flex. Camshaft endplay is a trick to set and needs to be done correctlly. If you want to see my project do a search for "roller cam upgrade" Good luck!!
