Electric Hatch Actuator
Old 02-25-2010 | 11:55 AM
Default actuator
Originally Posted by bajabob
nice you say it in good shape? why arent you useing it ? how much do you want for it???
pm me your email or phone number i can snd pics by email or a video by phone of it working. I got to install on boat i bought but it was to short. i need 30 closed 50 opened. it was advertised as 30" with 18 inch shaft. so closed it was 18 and opened it was 30.
BIGMC69 is offline
Old 07-05-2011 | 10:58 AM
help....I have the same Hatch Actuator (saej1171) my motor is fine. The center gear has a couple teeth that are broken and it gets stuck when down sometimes. Does anyone have a center gear they want to sell? Get back to me, Thanks
checkmateman is offline
Old 07-10-2011 | 04:48 AM
CP Performance sells them. The entire assembly. You need to know what your unit is regarding extended stroke and what it is in the relaxed position. I think you measure from the center of the bolt hole to the center of the bolt hole ?????They have them available with stainless steel covers, nice but a little pricy.
Typically the actuators get corroded internally, if you take them apart, lube up the gears and motor you should be fine. But what we all do is hit the button it works then does not work and we keep playing with it. What happens there is a little set of contacts inside of the motor that release if the hatch is stuck. If you keep hitting it the set of contacts gets fried and no longer make a good contact. Now you have to the the new assembly.
Post what you end up doing.
Brian
Big Boys Toys is offline
