Electric Hatch Actuator
Old 02-22-2010 | 03:11 PM
Default Electric Hatch Actuator
My Motor Is Bad Where Can I Buy Just The Motor ????
bajabob is offline
Old 02-23-2010 | 07:38 AM
[QUOTE=bajabob;3052329]My Motor Is Bad Where Can I Buy Just The Motor ????[/QUOT
What kind do you have, i just replaced my whole unit due to the worm gear, motor is still good..
theadamv1 is offline
Old 02-23-2010 | 09:40 AM
the motor is a redmond modelpe26630 saej1171marine
bajabob is offline
Old 02-24-2010 | 10:29 AM
Default actuator
what is the distance closed and opened i may have a complete actuator for you
BIGMC69 is offline
Old 02-24-2010 | 03:24 PM
it is about 18in close i think its opens 10im or more . how many is your close and open ??
bajabob is offline
Old 02-24-2010 | 04:18 PM
are you certain the motor is shot? Many have problems with the relay which can make them stop or go really s-l-o-w
$0.02
Caydens Cat is offline
Old 02-24-2010 | 06:09 PM
Default actuator
18 closed with 12" shaft so 30 open
BIGMC69 is offline
Old 02-24-2010 | 09:53 PM
nice you say it in good shape? why arent you useing it ? how much do you want for it???
bajabob is offline
Old 02-24-2010 | 10:11 PM
Strip Poker 388's Avatar
Rob
they also have a lift rating,the lift ratio,On my Hustler is 200lbs and the Hatch total weight is around 154.
Mine got real slow and just needed greaseing.The motor should be easy to get,
Strip Poker 388 is offline
Old 02-25-2010 | 07:52 AM
i did take it apart and clean it that part is good . i really just need the motor i have this set up on both my boat one is a forumula :.iclean that one and it works good .the baja does not . the hatch is not the promblem thanks for the info i switch them on the boats the forumula has a heary hatch then the baja
bajabob is offline
