Which brand and weight of OIL for 502 mags?
Best oil
Not going to say where? But have built a lab where oils are tested and graded cool place if you like watching things blow up or get trashed in heat or -50degF temps. Problem with synthetics (all though good)is they tend to create more windage robbing you of horse power. There have been many of studies and $ for $ regular oils are the best bet...Can't tell you results of who has what and does what and why. But I only use Valvoline Racing Oil 20-50 in my ride, It's a LOCK BABY.
1 Post
I recently charged my outdrive lube to Amsoil, after hearing a pile of good things about it. Just wondering if anyone has used there marine engine oil? I usually use the Merc oil [semi synthetic] but, wanted to switch to a fully synthetic, but, the Mobil 1 that I have been able to find locally is all 10W30 or 0W30, I have found a local Amsoil dealer with good prices, and wanted to get some input before I tried there engine oil, Thanks!
Michael
Michael
1 Post
Michael
Michael
Same oil recomendations for a 96 454EFI? The Diesel oil idea makes sense, I assume because much like Diesels, boat engines are always "working". I seem to remember Diesel Oils having a higher amount of detergents as well, does this help in the marine application also?
Thanks!
Michael
Thanks!
Michael
Ken
We use and recommend Brad Penn 20W50 High Performance Oil. Its designed to offer higher performance engines the cold temperature operational benefits of an SAE 20W engine oil while providing the desired film strength; sealing abilities, bearing, crankshaft, piston ring and valvetrain component anti-wear protection of an SAE 50W oil at normal engine operating temperatures.
Ken
1 Post
Great! appreciate the info! I looked it up online and Amsoil sell a "Marine" engine oil, but, its 10W30 they claim it will replace the Merc oil, which I think is 25W40 or 25W50? The other oil they list that appears to be geared toward Diesel/Marine engines and its 15W40. I didnt see any "Marine" 15W50? Is it Marine or Automotive oil?
I guess what I am asking is what would work best in my 96 454EFI, Its no rocket or anything, but, I would like something that extends longevity and I have had great luck with synthetics in the past, Thanks!
Michael
Michael
Michael
Michael
you cant buy it off the shelf since its not street legal, but napa, etc will order it by the box (6). I can normally order it that morning & they will have it ready for pickup in the afternoon. It's about $9-10 qt.
Michael
Michael
The big reason was that the levels of zinc/phosphours were substantially higher than over the counter engine oil.
Zinc is an anti-wear additive and over the past 5-6years the oil manufactures have been dropping the levels of zinc.
They started in the 1200-1400 parts per million range and are now down to the 1000 ppm tange, soon to be dropped to the 600-800 range
