Oil Sender
Old 04-12-2010 | 06:57 AM
Default Oil Sender
Can anyone tell me what sending units are used for Gaffrig oil pressure guages? I have the one's with the red indicator light in them.
Thanks for any input .
Adam V
theadamv1 is offline
Old 04-12-2010 | 12:09 PM
If they are "Gaffrig Precision Instrument" redline guages, then they are Livorsi guages. You need to use a Livorsi sender.
Griff is offline
Old 04-12-2010 | 12:17 PM
"Gaffrig Precision Instrument" is what they say on them, no where does it have Livorsi on it. So is that what was put on them AFTER gaff & livorsi merged?
Old 04-12-2010 | 12:59 PM
Default Fixx
Gaffrig/livorsi never merged,livorsi stole or used a few designs from gaffrig..
you need gaffrig senders, call mike and order them..
224-569-2900
FIXX is offline
Old 04-12-2010 | 06:37 PM
Gaffrig and Livorsi never merged.
There were two companies using the Gaffrig name. One was Gaffrig Precision Instruments and one was Gaffrig Performance.
There was a lawsuit over the trademark of the name and Gaffrig Performance won and got to keep the name.
Gaffrig Precision Instruments changed there name to Livorsi Marine.
224-569-2900
I don't think so.
Gaffrig Precision Instruments is now Livorsi Marine and he needs Livorsi senders.
Griff is offline
Old 04-12-2010 | 06:41 PM
BTW, I have the same guages. The are Gaffrig Precision Instruments aka Livorsi.
Griff is offline
Old 04-12-2010 | 08:25 PM
Gaffrig or Livorsi... whatever you want to call them. Either one uses a stock Mercury sending unit.
cubicinches is offline
Old 04-14-2010 | 07:21 AM
WOW talk about confused...lol, so is it gaffrig, livorsi, or merc sender i should use??? lol I looked at the Gaffrig sender online and it looks diffrent than what my old one is, mine has a spade connector on it and the gaffrig looks to use a threaded nut for the sence wire... but who is to say my old one is the right one???
Old 04-14-2010 | 07:22 AM
good looking set up btw Griff
Old 04-14-2010 | 08:39 AM
I been researching this as i have the same gauges with the red lights.
I found a new oil pressure sending unit in the package in my boats cabin. It was a livorsi sending unit. I imagine the previous owner installed these redline gauges, and had a spare sending unit.
I was told there are two sending unit styles used. Standard and vdo. Obviously VDO is for vdo gauges. Some boats came stock with VDO gauges back in the day, so switching to gaffrig gauges caused erratic readings without changing senders. Also the oil pressure sender must be either a 80psi or 100psi relative to the gauge.
This does make sense, although i have not yet tested this advice myself. I doubt gaffrig and livorsi were manufacturing their own sending units with different resistance values.
Best bet though i would say is to call gaffrig or livorsi and ask them. Im sure this is a question they have answered a million times....................
MILD THUNDER is offline
