Originally Posted by GERRYM454
(Post 3093223)
I use copper pipe and non lead solder it into a steel fitting and cut to needed lenght. I install the fitting witha gas resistant sealer and have never had a failure. the parts are universally available and inexpensive.
I know USCG rules are you need check valves. But I delete them as a possible source for fuel blockage. I would not use plastic tubes for fear of the plastic getting hard and cracking. Use aluminum or the copper pipe. It really is quite easy to make a new one.
2 Attachment(s)
IMCO makes tanks and custom pickups in house. the prices are very reasonable. I had a custom 3/4" pickup made for mine... The stock 3/8" just was not going to work. They can make something for you, or pull a stock screw in type from there stock. you will be very happy with the service and price.
The pics are before I cut to size and angle cut the end. Its best to keep the pickup about 1/2" or so from the bottom with a 45deg angle cut. That will solve any water build up on the bottom of the tank just let your water sep filters do what they are there for. Some guys install the pickup too high and then after some time the water builds up and one day you are sucking lots of water. Better to keep the tank clean by sucking off the bottom and like I said let the sep filters do the work.
Thanks DonROC for tha pics any Idea on cost?
I will try calling them I am cautious of some metals like copper because of the ethanol in the fuel these days and possible additives in the future. I use methanol on my turbocharged cars and It doesnt like some metals very much So I always keep that thought in my head when dealing with fuel. I figure that probably why the swtich to plastic was made but that one from imco looks like stainless? |
My boat currently has no check balls / anti siphon valves
Thats how it was when I got in there figured if the MFG wanted them they'd be in there. |
Originally Posted by 30ctsutphen
(Post 3094121)
Ok, dumb question. My pick up tube won't come out. It appears to be welded to the tank. It's a 280 PQ Silencer. I've been having what may be a fuel block problem (I've discussed on other threads). Any suggestions how I can remove/replace the existing tube?
Originally Posted by stevewy
(Post 3097409)
(Post 3097409)
| All times are GMT -5. The time now is 10:14 AM. |
