496 Manifolds On A 454
Old 04-22-2010, 09:28 PM
Default 496 Manifolds On A 454
Do the aluminum 496 manifolds flow any better than the steel 7.4 manifolds, have access to a set just wondering if id be worth changing them.
MEDIUMPIMPN is offline
Old 04-22-2010, 09:52 PM
It will be worth close to 20 hp! Plus you will loose at least 50-60 lbs. Do it! You'll be happy you did.
endeavour32 is offline
Old 04-22-2010, 09:56 PM
Same bolt pattern - you need different bolts. The ones with the 496 are metric.
Keith Atlanta is offline
