-   -   Ok got drive off....Videos included.... Whats wrong? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/229126-ok-got-drive-off-videos-included-whats-wrong.html)
FuelinAround 04-25-2010 05:06 PM
Sorry post with videos moved here http://www.offshoreonly.com/forums/d...ched-help.html
US1 Fountain 04-25-2010 05:22 PM
Just realized you have the drive off
FuelinAround 04-25-2010 05:27 PM
Check out videos on other thread I screwed up the html and never knew I created this one. The drive will not even shift when the sifter cable is unattached.
US1 Fountain 04-25-2010 05:31 PM
Unattached at where?
FuelinAround 04-25-2010 05:34 PM
If I unattach the shifter fork under the back plate of the drive and shift it from where that little spring and ball sits onto
FuelinAround 04-25-2010 05:35 PM
There is a good video of it on the other thread http://www.offshoreonly.com/forums/d...ched-help.html
In The Pink 04-25-2010 08:20 PM
From what i am seeing, you haven't pulled the drive off the boat yet. The shifter cable in the gimble housing may be butchered up or even broken. You need to pull the drive off the boat to see if this is your problem.
firehawkcat 04-25-2010 08:50 PM
I had a similar problem cable broke it would go in reverse but would not do anything else. You can switch the cable pretty easy back nuts off pull gear houseing back about 3/4 to 1" just enough room to see what is going on just make sure all o rings are in correct place after slinding new cable thru the cable bellows have a partner with you they are not heavy but not that light either
FuelinAround 04-25-2010 08:56 PM
Not the cable... singled it out and it works fine.
firehawkcat 04-25-2010 08:57 PM
Go to you a manual called Seloc mercruiser stern drives it is like a hanes or chilton manuel gives step by step. Also a Mercury Mercruiser #28 service manual I have both very helpful on just about everything under the engine hatch Got mine on ebay but sounds like you need help asap
