489/496 cam ok with 496 exhaust >
Old 04-25-2010 | 11:12 PM
Default 489/496 cam ok with 496 exhaust
I am in the middle of building a 489/496 stroker out of my 454 for my 91 baja, I just wanted to confirm i am ok with the 496 exhaust i got as a pull from a late model boat. The cam I installed in engine is a crane 134241. The engine has fully ported heads and air gap intake. I have the complete install kit so the springs and everything match. Just making sure i dont have to worry about engine sucking water up the exhaust.
grjdc1 is offline
Old 04-27-2010 | 12:25 PM
any tried simular setup? going in a 91 baja 226? any ideas on speed?
grjdc1 is offline
Old 07-18-2010 | 08:22 PM
Anybod know if this cam would work with my 489/496 stroked 454? just making sure the 496 exhaust will work?
Operating Range: 2500-5500 RPM
Duration Advertised: 286° Intake / 296° Exhaust
Duration @ .050'' Lift: 226° Intake / 236° Exhaust
Valve Lift w/1.7 Rockers: .534'' Intake / .553'' Exhaust
Lobe Separation Angle: 112°
grjdc1 is offline
Old 07-19-2010 | 02:16 AM
Not sure. It will be borderline for reversion with 496 exhaust. The Crane 132561 would be a little better since its on 114 lob sep. It was used in the 420 and 525SC but they also both had Gil exhaust.
Griff is offline
