Transom Exhaust gaskets
Old 05-10-2010 | 09:36 AM
Rookie's Avatar
Default Transom Exhaust gaskets
Where do I find these gaskets to seal around my exhaust? 6" x 4" inner diameter
Rookie is offline
Old 05-10-2010 | 12:15 PM
http://www.cpperformance.com/c-467-transom-rings.aspx
Griff is offline
Old 05-10-2010 | 12:34 PM
I made mine....One stop at Auto Zone and pick up some "fell Pro or Mr. Gasket, or any other sheets of gasket material and cut them yourself and I used Clear silicon....set me back a solid $10 and I have plenty left over..... Works just fine
joe27baja is offline
Old 05-10-2010 | 01:31 PM
Rookie's Avatar
Thanks Griff, I can never find anything on websites.
$20 a gasket is a little extreme.
I will be going the Autozone or Mcmaster Carr route. That is what I planned on doing if I couldn't find any. (reasonbly priced)
Rookie is offline
Old 05-10-2010 | 01:40 PM
Strip Poker 388's Avatar
Rob
find a locall rubber place , its just some kind of neopreame rubber.might find some that will hold out to some heat, the ones I got from stelling ya could cut with a box cutter.
Strip Poker 388 is offline
